Major XP Problem (Help!)
Forum Windows XP : Windows XP General Discussion - Major XP Problem (Help!)
As of recently when I boot up my computer it gets passed the BIOS load up, and then moves onto loading Windows XP Home Edition. After XP loads up and loads all of the startup programs, it restarts itself. No warning, nothing.
I figured maybe it was an IRQ conflict problem, moved some cards around in the PCI slot and nothing happend. I removed my half-dead DVD-Rom drive that has been giving me trouble lately, nothing.
Any ideas as to why? This is really really aggrivating.
System:
Athlon XP 1700 stock
ECS K7S5A MB
256 PC 2100
SB Live
GF2 Mx 400
Generic 10/100 lan card
Sponsored Links
you are getting a major error, in xp major errors xp reboots itself hit f8 while booting and boot into safe mode from there try to resolve your problem not sure in xp you can go back to previous date setting if you can try that.
Reply to kallabos
- 0 +
If you have a computer that can connect to the internet, go to the Microsoft knowledge base. They have a fix for this.
en Xristos
Reply to delpart
<A HREF="http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q320299" target="_new">Windows XP Restarts Unexpectedly (Q320299)</A>
With that page, it isn't told that you should uncheck the "Automatically Restart" option. But, do that. Keep "Write an event to the system log" checked. Then read the How-To for viewing the event logs.
Bryan
_________________________________________________
<A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> won't be down for a while. My site is on a server at RackShack (Texas), and according to the announcement <A HREF="http://www.cwstatus.com" target="_new">here</A>, it'll be some time after the new data center is up before he does anything with them. I don't mind the downtime, because it'll be worth the awesome performance he's describing to us.
Reply to btvillarin
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Major XP Problem (Help!)
There are 1377 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
