Which system component affects sound
Hello,
Which system component in a laptop might I have seleted to end up with no audio?? All possibilities have been exhausted. The test tone doesn't even play???
3 answers Last reply
More about which system component affects sound
  1. A laptop should have two to four speakers (two is common) and I think that they should work unless you don't have a proper audio driver, the audio services aren't running, or you have a hardware problem with your audio.
  2. Does your laptop have an HDMI port? Then the standard audio device may have been switched to HDMI. You can change that back to onboard audio in control panel.
  3. perhaps its on mute?
Drivers Laptops Audio Components Windows 7
