I have a Compaq Presario r4000 that was dropped. Since then , there are vertical bars on the right side of the screen. I changed the screen, but that didn't solve my problem. Someone told me this is obviously a graphics card problem. Can I replace the graphics card on this?
Sponsored Links
Probably not. You'll likely need a new motherboard. What's your current card?
------------------------------ Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17", 24" | Win 7 x64
Reply to frozenlead
Thanks for answering. Under "Display Adapter", the laptop shows "ATI Radeon Xpress 200 Series." Is there any way to tell for sure that that is my problem?
Message edited by veronicak5678 on 05-18-2009 at 02:25:38 AM
Reply to veronicak5678
If you replaced the screen, that rules out the screen (well, it still could be the screen, it just makes it many times less likely). The only other thing related to video is your motherboard. In that regard, I would take the unit apart and make sure no heatsink got bumped around and is making it thermally unsound. I really doubt that will fix anything...but it doesn't cost a dime and it's worth a try.
Else, your motherboard is bad. Since you've an X200 GPU, that's integrated into your motherboard - which is what leads me to believe that's your issue.
Reply to frozenlead
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptop Display Problems
There are 900 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
