Breaking news, site updates...
how to set them? right now im using analog but the text doesnt look good im using 1400x1050 resolution,,.... any help why....and how to set it to digital connection? i have DVI cable already thx for any help dp
Try using the monitor's native resolution... any other could be OK... could be crappy, too.
Try using the monitor's native resolution... any other could be OK... could be crappy, too. problem solved when i reinstall the catalyst driver i dont know why before it doesnt have 1440x900.... after reinstall got that resolution thx for ur help
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
