System Restore creates problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Long story. Here is the short version.
1) While cleaning C drive, somehow on a VAIO, it stopped recognizing built
in DVD RW and CD ROM drives. My computer does not show existence of DVD and
CD drives.
2) So I decided to use system restore and restored it to a point one month
back
3) After restore, I went to My computer to see if DVD and CD drives are
visible. They are not. So I guessed that restore did not work
3) I then did "un-restore" to get the system back to today's state. It said
it worked. But after this "un-restore" my OEM installed Norton Internet SW
does not load. It says it can't find the SW. So, I thought fine I will go to
their site and download it and re-install, but then I find out my IE is not
working.
If I go to command prompt, with cmd, and do "ipconfig" it is fine. I can
ping yahoo.com so I know connectivity is fine. But when I start IE, it says
server not found so now I have lost Norton Internet SW (firewall, anti-virus
etc) and I can't go to internet since IE is not working. What a mess.
Not sure how to get out of this. Any ideas?
Thanks in advance for help.
Note :: I am using XP, to be specific Media Center Edtion 2005. But this is
not a MCE issue, seems to be generic XP issue.
G
Guest
Guest
If you really want to use something like System Restore - consider Symantec
GoBack 4.0. It is system restore on steroids. The file that retains the
goback information can be made (during the time of installation) to be up to
8 gig in size.
Now, that seems like a lot, but without careful planning you may still run
into the problem where you can only go back 3-4 days (or less). This would
occur if you have many HUGE files, such as movies on the monitored drives.
Delete 2-3 movies and you have used up your goback space. But on a normal
computer, if there is such a thing, GoBack will usually allow you to return
to where you were a month prior. It all depends on YOUR usage.
On my test computer I only monitor the main hard drive which has partitions
C-D-E. All movies, huge CAD files etc are kept on drive F. My Ghost image
files are kept on a removable hard drive. Needless to say I don't monitor
these drives.
Couple GoBack (for short term protection) with an imaging program, such as
Ghost or True Image (for long term protection) and you are fairly bullet
proof.
Regards,
Richard Urban
Microsoft MVP Windows Shell/User
Quote from: George Ankner
"If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!"
"masik" <masik@discussions.microsoft.com> wrote in message
news:ED5CFB44-2171-43CC-9F8E-EEF4B551F506@microsoft.com...
> and
> CD drives.
> back
> to
> not
> working.
> says
> anti-virus
> is
G
Guest
Guest
>8 gig in size.
Being as it is a Symantec product I would say it is more likely to
resemble System Restore on Crystal Meth or LSD (or both).
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
G
Guest
Guest
"masik" <masik@discussions.microsoft.com> wrote:
>Hi Ron,
>Thanks for the tips. I did uninstall drives from Device Manager and rebooted
>the PC still not luck. It says in property that
>Windows cannot load the devivce driver for this HW. The driver may be
>corrupted or missind (Code 39).
>And due to system restore issues, IE does not work so I can't connect to
>internet, I am writing this from another PC. So looks like I am hosed.
>Not sure how to get the drives working. I have recovery CDs I can at least
>get the PC restored to factory defaults. Any clues there?
Here is a registry patch that will clean out all CD drive references
from your registry:
http://www.aumha.org/downloads/cdgone.zip
Download, unzip and install it then reboot the computer.
Good luck
Microsoft MVP
G
Guest
Guest
Hi Ron,
Thanks. I did not use this, was not sure about touching the windows
registry. But ultimately the problem was in registry. I ended up contacting
Sony and paying for the support, since my PC is now 2 & half years old and
out of warranty. :)
But here is the solution for the community, so if others face the problem
they don't have to pay. Pay attention to the Error code you see in the device
manager. I had Code 39. Go to Microsoft knowledge base and search on Code 39.
It says if you have problem with Easy CD something, use the process. That is
the process you use.
Somehow, two entries get added to your registry High Filters and Low
Filters. These entries affect the drive recognition and thus operation under
wondows. The MS article talks about which entry in the registry to look and
edit. Basically delete Low filter and high filter and reboot. That worked for
me. But before anybody tries this out, read the MS article carefully.
Thanks again to all for helping me out. Looks like I am set for now.
> >Hi Ron,
> from your registry:
> Good luck
> Microsoft MVP
G
Guest
Guest
Hi,
If you followed Ron's advise and used the cdgone.reg file you would
have achieved the same result. Of course minus the cost of tech
support from Sony.
Regards,
Bert Kinney MS-MVP Shell/User
http://dts-l.org/
masik wrote:
> Hi Ron,
> the windows registry. But ultimately the problem was in
> registry. I ended up contacting Sony and paying for the
> support, since my PC is now 2 & half years old and out of
> warranty. :)
> face the problem they don't have to pay. Pay attention to
> the Error code you see in the device manager. I had Code
> the process. That is the process you use.
> Filters and Low Filters. These entries affect the drive
> recognition and thus operation under wondows. The MS
> and edit. Basically delete Low filter and high filter and
> reboot. That worked for me. But before anybody tries this
> set for now.
>>> Hi Ron,
>>> Manager and rebooted the PC still not luck. It says in
>>> property that
>>> driver may be corrupted or missind (Code 39).
>>> can't connect to internet, I am writing this from
>>> CDs I can at least get the PC restored to factory
>> drive references from your registry:
>> Good luck
>> Microsoft MVP
