Recently I had to reinstall windows again after having a problem with my GPU having serious issues (load would go to 99% when mouse goes inactive after about a minute).
The issue I'm having now is deleting the disk partition that windows was previously installed on (c).
I decided to delete the partition on my bigger drive (465gb), reformat it, and installed windows on it. I made it the active, default drive. (It says Boot, Page file, Active, Crash dump, Primary partition).
The C: drive that i'm trying to delete wont allow me. (I turned it into a dynamic drive accidentally but either way was getting a similar message before). Now it says "Windows cannot delete the system volume on this disk".
I have read multiple guides, and have tried using command prompt and etc... I don't know what else to do from here.
Ideally I want my bigger drive to be the one windows runs off of because the drive windows was previously installed to (c) is only 75 gb.
Note: I have an img file that can show you my exact disk map in the disk management section but not sure if I can attach a file.
LINK to Disk map: http://s9.postimage.org/xt4ez1cj3/disk_part.png
Note: In the image you will see that I made another partition of the same drive (J) which was an accident. However, I am still trying to remove the 75gb partition that used to be "c"
