Tom's Hardware > Forum > CPU & Components > Sound Cards > help with two sound cards in one system
Forum CPU & Components : Sound Cards - help with two sound cards in one system
hey guys, here is what i'm thinking about doing; install two sound cards in one system. the reason for this is i want two audio streams on different set of speakers. lets say one set of speakers will be placed in the basement and the other in another place.
</font color=red><b><font color=orange>i Own all the rights tO yOur sOul. .r nerber ig vash gOughen nOre midat
Sponsored Links
Do u want two different streams or the same one?
If you want the same one just put a splitter to the rear, center , and sub cables going out from the sound card
If you want two different streams I'm not sure but there could be a bit of conflicts
<A HREF="http://www.freewebs.com/lb19984/" target="_new">My Rig</A>
Reply to lb19984
- 0 +
You would have to have 2 different sound cards I believe to allow for 2 different streams at once. It would make it easier at least. Most media players (wmp, winamp, etc) allow you to choose your output so just set one player to one sound driver and another player to the other sound driver. I've never tried it but I see no reason why that wouldn't work.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
Reply to folken
spank... i mean thank you
Reply to scamtrOn
Yes, I've heard of pros doing this. They configured each program for the card they wanted. But I'm not sure how.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
i'm working on it. its really messy though. you got to go through so many different settings just to change something simple.... sucks
dood, when was the last time you saw piii man? is he still around
Reply to scamtrOn
You can do this - I have 2 Sound systems on my DAW... I expect it to work the same way with 2 'normal' sound cards too... I have the o/b sound (An Asus P4B533 m/b) set as the default in windows - so any normal windoze sounds (WMP etc.) run through that, and then Cubase etc and/or winamp, (since this is the easiest program in which to change sound devices), running through my Edirol DA2496...
'Stupidity is an often fatal disease' - R. A. Heinlein
Reply to KeillRandor
- 0 +
Hey Scam,
It really depends on the software once the cards are up and running. Some software, like Tracktor, Cakewalk, or other DAW software expect people to have multiple I/Os. Other stuff geared toward the consumer may not be so intuitive. Also, you may have to run completely different apps for the same thing, like using winamp for downstairs and WMP for upstairs. What are you looking to run, anyways?
Reply to jheine
There are 1307 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
