It's pretty easy if you know what to do. The actual repair will only take minutes, but fitting it in the case without problems could take hours. The last one I did took about 5. I didn't take any pictures from it, unfortunately, and the notebook is with it's owner, now.
The tools I used (for the repair, not for dismantling the notebook itself)
-soldering iron and solder (duh). I prefer .032", but if you're careful you can use bigger.
-desoldering iron (helpful, but you can get by without it. we all screw things up.)
-Some wire, I think I used 12 gauge. You can use different wire, depending on your current needs. You can probably go down to 21 or 22 if you just don't have space. You won't need a lot, probably less than an inch.
http://www.powerstream.com/Wire_Size.htm
-A good pair of wire cutters and sets of needle nose pliers and other types of cutters. Never know what kind of snip you're going to have to make. I've got a nice craftsman professional set I use.
-An ohmmeter/multimeter to check your connections
-A dremel tool/drill with various size bits and sand bits to modify the chassis, if necessary.
-A hot glue gun and electrical tape to prevent shorts and hold things together if you need to.
That's about it, I think.
Now is also a good time to clean out your heatsinks and reapply TIM, if you want/need.
