Chkdsk C: /f /r does not solve Disk problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
Brother Brock wrote:
> Even after scheduling `Chkdsk C: /f /r /v' in the system startup, the
> `errors in the Volume bit map' does not correct. Any other solution to
> clear this error?
> Thanks for any help & replies.
> Brother Brock
Have you checked your hard drive's physical health? Test the hard drive
with a diagnostic utility from the mftr. Usually you will download the
file and make a bootable floppy or cd with it. Boot with the media and
do a thorough test. If the drive has physical errors, replace it.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
> `errors in the Volume bit map' does not correct. Any other solution to clear
> this error?
> Brother Brock
What is telling you there are errors in the volume bitmap? Are you
running into any operating issues?
Rock
MS MVP Windows - Shell/User
Ask the community
