WD Raptor question on size and power
I just wanted to clarify the actual size of the WD Raptor 74 GB hard drive. Is it the same size as a normal 80 gig drive (80,000,000,000 bytes = 74.5 GB) or did they measure GB in trillions of bytes like other hard drives making it's actual size 68.9 GB?
Also, I was wondering if my 420W power supply is going to get overloaded by adding the WD Raptor SATA drive. My system is an Athlon 2600+, 2 IDE hard drives, 2 CD/DVD drives, Radeon 9800 Pro, and 4 case fans. Will it be okay to add the SATA drive or should I remove one of my old IDE hard drives to help save power consumption? It would be nice if I could keep it, but my older one is only 40 GB so I could do without it if necessary or if anyone could advise what wattage power supply I should have to be able to keep everything. Any help is appreciated. Thanks.
4 answers Last reply
More about raptor question size power
  1. Quote:
    What are your current rails?
    3.3
    5
    +12
    -12 etc...
    _______________________
    <A HREF="http://www.moviewavs.com/MP3S/TV_Shows/Simpsons/flanderssong.mp3" target="_new">Audio Sig</A>
  2. all hard drive companies that i know of use the cheater method of determining hard drive space. technicaly one gig is 1024 megs, but they use the one gig = 1000 megs so they get to say it has 80, or 74.6 in this case but its less.
    wpdclan.com counter-strike game server - 66.150.155.52:27015
    now featuring valve security module!
  3. My 74 GB raptor shows up as 69.2 GB in windows.
    No it won't. Hard drives take a decent amount of power (20 W IIRC) to spin up, and use only 5W idle. You can check wd's site for more accurate info though.
    s signature has been formatted to fit your scr
  4. Wow, my Raptor shows up as 69.2 gb also. [/spooky!]
    <font color=red><pre>\\//__________________________________
    And the sign says "You got to have a membership card to get inside" Huh
    So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Hard Drives Wd Raptor Storage
