well, I know a little about computers, but not enough for this simple job, apparently.
put a couple computers together, but that was years ago.
I'm trying to install this cd burner, which I thought would just plug in, but when I try to access it, my computer locks up.
my computer does recognize it as drive d, and I THINK I've got the master/slave jumper set right.
I'm pretty sure the hardware's ok --- any suggestions?
win98se, via chipset?
it's an old ibm 300gl, and I'm trying to install a btc cd burner model bce 62ie.
just 2 drives --- my harddrive and this burner.
the cd-rom I pulled out worked fine.
thx
*edit*
my 2 drives are on 2 separate cables using 2 separate controllers.
thx
*edit*
