Tom's Hardware > Forum > Home Theatre > HDTV > will this work with standard comcast cable and an xbox 360?
Forum Home Theatre : HDTV - will this work with standard comcast cable and an xbox 360?
http://www.newegg.com/Product/Prod [...] 6889160003 here is the t.v. my friends wants but I want to make sure it will work for his 360 and basic cable.
Sponsored Links
Quote :
Hmmm..... for the basic cable, same applies to this thread as your previous....
http://forumz.tomshardware.com/ce/ [...] 52875.html
For the 360, just read the newegg reviews right on your link. Several references to using that TV with the 360 with good results.
Reply to carver_g
Basic cable will work with the TV provided they get a cable box with the service that has the RCA red, white, yellow composite cable output. Every cable box that I have seen has these so that should not be an issue. I am sure that you could always just contact the cable company and get a box.
If they will not let you get a cable box for you standard cable, you can try and use an old VCR as a converter box that will take the Coaxial connection and allow you to output it to the composite signal the TV needs. (I have not tested this last idea and don't know if it will work. I have only done the reverse, but it was successful)
Reply to The_Hunted1
You're right; that TV doesn't have a built-in tuner.
Reply to carver_g
There are 1100 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
