G
Guest
Guest
Hey guys...
I'm going to be building a new PC within the next month or so and I'm really stuck on which memory to select for my setup.
Here is what I'm looking at:
Asus A8N-SLI Deluxe
AMD Athlon 64 FX-55
Asus nVidia 6800 Ultra [V9999][x2]
Maxtor 300GB SATA [x4]
Western Digital Raptor 74GB SATA
Yes I know....perhaps a little excessive and expensive but I have the money to play with and I've always wanted to build a tank so whatever. Now I'm reading the forums here to learn a little bit about timings/latency and 512MB sticks versus 1GB sticks to try and make a good decision for my setup. That new Asus board [http://usa.asus.com/prog/spec.asp?m=A8N-SLI Deluxe&langs=09] says it can handle either ECC or non ECC memory so here are my choices:
1. 4GB of Kingston HyperX
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-145&depa=0
2.5-3-3
ECC
2. 4GB of Mushkin
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=140579
2-3-2
ECC
3. 4GB of Corsair XMS w/ the pretty LEDs!
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-503&depa=0
3-3-3-8
non ECC
4. 2GB of either Kingston HyperX or Corsair XMS
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-160&depa=0
or
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-544&depa=0
Those are just a few choices...I don't want to fill up the entire post with 10 different choices and links. This computer is going to be used for anything and everything...gaming/storage/multi-tasking whatever I need it to do. But my questions to you guys are:
1. In what situations [gaming VS multi-tasking] would I see performance increases and performance drop offs with a 4GB [higher latency/timing] setup versus a 2GB [lower latency/timing]?
2. I understand ECC is usually only seen in server setups. Would ECC benefit me at all with a home setup? Would gaming benefit from ECC at all?
3. I was reading up on the Muskin memory that I mentioned earlier and it is 'Dual Bank'. Looking at the A8N-SLI QVL Mushkin is not listed in there...does that mean the motherboard does not support it? And does that mean that any memory module that is not listed in the QVL is not supported by the motherboard?
Any and all feedback and advice on this matter is appreciated.
Thanks guys!
Asus A8N-SLI Deluxe
AMD Athlon 64 FX-55
2.5-3-3
ECC
2. 4GB of Mushkin
2-3-2
ECC
3-3-3-8
non ECC
or
Thanks guys!
