Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Will Diablo 2 run at 19' widescreen Lcd monitor?
Forum Computer Peripherals : Flat Panels/ LCDs - Will Diablo 2 run at 19' widescreen Lcd monitor?
im planning to buy a 19" widescreen LCD monitor that will run 1200X(xxx-forgot the resolution).
my question would be, since D2 runs at 800x600, will it play smoothly, or VIEW it nicely at FULL SCREEN ? even if the screen ratio and resolution is a mismatch ? thanks alot!
PS: diablo 2 only has a 800x600 res, it cant be changed
Sponsored Links
I think you can put in a few command line prompters into the target...change
res to 1280x1024
Reply to deusex
- 0 +
I don't play fullscreen, it's ugly.
I usually use d2loader and run it in windows mode, the color looks awesome that way, and it's nice for muleing items to yourself with 3-4 d2 running.
Reply to kev1n
So if you have a wide screen monitor and can play an older game in windowed mode, it does not stretch. I have been wondering how the older game look on a wide screen monitor, or rather, what is the best way to play them. Having everything stretched does not seem appealing.
Reply to Titanion
There are 1331 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
