Hi,
I've just been given 2 sticks of HP Ram, each stick is 1gig (DDR PC2100, CL2, ECC, Reg)
When I put a strip in (on it's own) I get one of the following:
The monitor doesn't turn on.
The PC turns on when I attach the power cable , before I switch it on.
Then, if the monitor is working, it always gets stuck on updating the ECSD. If I push it to update manually, it works until the next bootup.
I did have this ECSD problem when trying to add a PCI USB2 card, so I gave up & returned the card.
With the 2 sticks of 256Mb PC2100 RAM I have usually, I have no problems.
Does anyone know what might be going on. It's a shame to think I can't use the RAM as 2G is a massive amount for me. The RAM is second hand from an old HP server but it should be ok.
Thanks for any help,
Ape
Spec:
AMD XP2400+
Gigabyte GA7DXR
512 PC2100 DDR RAM
Seagate 60G HDD
Win XP Home with SP2
Audigy Sound Card
Ape
Spec:
AMD XP2400+
Gigabyte GA7DXR
512 PC2100 DDR RAM
Seagate 60G HDD
Audigy Sound Card
