No, you don't adjust it. You're supposed to run DDR400 RAM with that CPU. Any attempt to make the RAM you have run the right speed for the CPU will mean a drastic overclock for your RAM, from 166MHz (DDR333) to 200MHz (DDR400), a 20% RAM overclock.
And your board might not even support manual adjustment. But if it did, using the higher setting could cause severe problems, including "no boot" or stability issues.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
