Let me start off by saying IF YOU HAVE A NEW COMPUTER AND YOU ARE BUILDING IT AND using an SSD with an HDD REMEMBER TO UNPLUG IT WHILE INSTALLING WINDOWS 7. Well as you can imagine, I didn't. It looked like it only installed Windows 7 on the SSD but not in the long run it didn't. So I started out just fine, installing my games, installing my most used applications, using the HDD with SSD and I was happy. Then one day I put my computer to sleep for the first time. Two hours later I start it up, my friends are on and I they ask me to put up a server I run. So I did, but I was going to backup it up. Since this game has a LONG loading screen I installed it on my SSD. Well I take the stuff on the SSD and I put it on the HDD and then I see copying 255GB! I FLIPPED OUT! I mean 255GB on a 120GB SS????? How could this be??? So I went into the folder right-clicked then clicked properties, and well it said it was 255GB? I couldn't understand so I looked around everything it seemed was 100x its original value. My RAM said it was 800GB even though it was only 8Gb that I installed. So I contacted Microsoft Customer Support after searching online. At first he thought it was a simple error, then it was a virus, then he said there was some link between the HDD and SSD that was causing this. So if anyone knows the fix to the 100x problem please share here. If not THE SOLUTION IS REINSTALL WINDOWS!!!!!
