Hy guys, I have a problem installing Win 7 x64 from a bootable USB I made with WinToFlash on a Asus X401A.
I know the stick is bootable because it loads windows files but after I chose language and keyboard and press install it says:
"A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now."
I know this is a known problem but I have tried all the solution I could find, Change from USB port 3.0 to 2.0, use Ultra Iso to write Win images to stick (Win 7 32,64, Vista 32,64) but to no avail.
Can someone plzz help me this is getting frustrating
Note: last night when I used WinToFlash for the first time to transfer Win to the stick, instead of copying the files manually after I format the stick, I managed to install Windows but the USB ports didn't work at all, I tried 3 different sticks and nothing and I didn't have any drivers on the HDD and with no way to transfer anything on the notebook I fuleshly decided to reinstall Windows but I ran into the same "A required CD/DVD drive device driver is missing" error.
On top of all of that the previous installation of windows wont boot, it says " windows failed to start. a recent hardware or software change might be the cause" and Repair your computer from the stick doesn't work.
