Tom's Hardware > Forum > CPU & Components > Sound Cards > Ever Seen Extension Cable for Audio Card?
Forum CPU & Components : Sound Cards - Ever Seen Extension Cable for Audio Card?
Has anyone ever seen an extension cable designed to bring a sound card's inputs and outputs from the back of a PC to the front?
My PC has all the audio inputs and outputs in the back. The PC is also located in an inconvenient place. That makes it difficult if I want to plug in different equipment. So, I'd like to find a 3 or 4 foot cable that I could use to extend the I/O ports to the front or side of my PC.
BTW, I know that you can buy audio panels that will plug into a drive bay on the front of a case, but that's not what I'm looking for.
I also know that I could probably buy several extension cables from Radio Shack, but I would prefer it if everything was bundled into a single shielded cable and then color coded. (Actually what I'd really like to find is an extension cable with a small panel on the end that would extend all my sound inputs and outputs, along with my USB, keyboard and mouse ports.)
Thank you.
Sponsored Links
There are 734 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
