Yes No
Ads
Tom's Hardware > Forum > Tom's Guide > Article Discussions > Tom's Ultimate RAM Speed Tests - misinformation
Forum Tom's Guide : Article Discussions Tom's Ultimate RAM Speed Tests - misinformation
Concerning "Tom's Ultimate RAM Speed Tests" . ..well let me just say that the technical experience of your article writers has gone down severely in the last several years.
Quote :
2 GB memory kits offering two DDR2-800 modules start at approximately $75, which can be considered a bargain given that 2 GB of main memory is enough to run all sorts of mainstream applications and games. More memory, meaning 4 GB, requires a 64-bit operating system, because Windows XP and Windows Vista will only be able to handle 3 GB RAM when the 32-bit versions are used. Although the 64-bit versions are equally reliable, almost equally fast, and driver support has improved a lot, be sure you double check if your devices and applications will work in a 64-bit environment.
Windows XP x32 can and WILL use all 4GB of ram if installed. However since a bit is reserved for system resources, the total amount usable for system processes, and applications, the total will be less than 4GB. Typically if you use a 512MB video card, you will see 3.25GB or less, and a 256MB video card will show 3.5GB or less.
It *seems* obvious that the witter of this 'article' has zero, real, hands on experience with such matters, and I truely did not even want to bother with reading he rest of this **** . I can see why Toms has taken the 'Discuss this article' link off of the main article pages . . .
Reply to yyrkoon
Quote :
WTH kind of ram are you buying? You can buy 4GB of DDR800 for less than that. I just bought 16GB of DDR2-800 for 140 (and a week later it was available for as little ast 4gb for $50.00.
What did that get me? All sticks would OC (with 1 2GB stick installed) to DDR-1000 at 1.8v (that's default). Half would hit 1066 at 1.8v and a few others hit 1066 at 1.85.
With 4 sticks installed, the fastest would hit 1066 at 1.9v and the slowest would hit 1000 at that speed.
This was plain old Adata ram from newegg.
If you're going for a super OC, then i guess it'd make sense to buy faster ram, but I don't see why you'd pay 2x as much. Hell, I've seen 2GB Balistix PC2-800 for something like $30.00 (maybe less)...for those that want D9 ram.
Reply to nilepez
You are correct about the 32-bit version of windows utilizing 4GB RAM, but that doesn't take away from the legitimacy of the tests. It's more like a minor error in reporting. The point of the article was to show that more expensive, "high-performance" RAM is not worth the money.
Reply to ch33sehead
There are 1913 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Why is my computer keyboard working in slow motion?
By hang-the-9, 25 days ago:
Try a new keyboard.
Best offers
