I have a Toshiba Satellite pro 435CDS and have to replace the memory battery. I have un-screwed all of the screws , but the bottom still will not come off so I can repalace the internal battery, please help tnx, Eric
Sponsored Links
The bottom of the notebook is probably clipped to the top with plastic clips that you'll need to break loose. (not break as in broken, break as in unseal) Generally notebooks' tops come off first, and then the motherboard is accessible. It's unusual that the bottom plastic part comes off.
------------------------------ Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17", 24" | Win 7 x64
Reply to frozenlead
- 0 +
Thanks for the info, I'll check it out.
Eric K.
Reply to wa2rkj
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Memory battery replacement
There are 890 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
