Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > [Solved] Help Choosing between laptops...
Forum Laptops & Notebooks : General Laptops & Notebooks - [Solved] Help Choosing between laptops...
Best answer from frozenlead.
Alright I'm in a dilemma right now don't know which to chose. So i either need a vote or which one would actually be better.
Each Laptop will have the same of the following:
CPU-Core 2 Duo T9600
Hard Drive-Seagate 250GB 7200.4
Wifi- Intel Wifi 5300
RAM- 4GB OCZ 800mhz low latency ram
Video Card- 9600m GT DDR3
Im getting a barebone laptop not sure which one to get..
MSI MS1722 17inch(1680x1050)
MSI MS1651 15.4 (1280X800)
I wanna know which one I should get.. The only high intense gaming is Prob between TF2 and L4D which i dont play alot..
Most games I play is DotA on WC3, CS 1.6 and CSS and I think the other game I would prob play will be DIABLO 3 and Starcraft 2 which are not intense games..
The other barebone I was looking at was an OCZ barebone
with Radeon HD3650 GPU with 512MB GDDR3 another 15.4
or if someone has a site that sells cheap barebone laptops by itself can you give me link if not which laptop should i go wit?
For those games, a 9600GT will power the 17" screen nicely. I'd get that.
Sponsored Links
Best answer
------------------------------ Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17", 24" | Win 7 x64
Reply to frozenlead
There are 1313 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
