Tom's Hardware > Forum > Audio > Audio Technology > HTPC to Reciever problem
Forum Audio : Audio Technology - HTPC to Reciever problem
First, the backstory.
As a Christmas present for my parents, my siblings and I plan on building a "new" computer. This computer will be capable of digitally outputting audio either through toslink or coaxial spdif to a 5.1 home theater receiver. We are purchasing a 500gb hard drive to losslessly store my parents entire cd collection(~150 cd's) in the flac audio format - think of this as a htpc that emphasizes on audio.
Now the problem.
I am trying to keep the audio as high quality as possible, this includes while being transmitted to the receiver. As a result, I would like to use toslink or a coaxial spdif cable to connect the sound card to the receiver. The stereo is ~30 feet from the computer, and the wire will be run under the house. However, toslink and coaxial spdif are hard to find in 30 foot lengths, and even then I have read that there can be audio problems when running the cables at that length.
Any suggestions would be greatly appreciated.
------------------------------ AMD Athlon 3700+ (stock)
Asus A8N-Sli Premium (v.1009)
Evga Geforce 6800GS 256mb @ 470/1100
1024mb OCZ Platinum EB DDR 500 @ 2-3-2-5
Sponsored Links
I believe I read somewhere that you don't lose signal strength over long distances with optical as opposed to coaxial. Sorry I can't remember where I read this I'm sure you can google the difference between the 2. Too bad there isn't someway to shorten the distance. I know you can transmit wirelessly to a receiver but don't know what kind of quality loss there is compared to hardwiring.
Reply to g-paw
- 0 +
Cost of coax and optical might be the same aquiring the same performance. You need to find a place that do special cabling. I would chose optical for my installtion which i have in my basement, for that lenght it might cost you over a hundred dollars.
If you chose copper type you should check a wire like the PBJ Interconnect or sowhere along that line.
That's why optical due to interference and less loss in very long runs.
Check for optical patch cable sites that do custom made. If you can find 2 25 feet optical cords and a coupler is most likely cheaper, cost would be around 30 dollars and up depending on material and the seller.
Reply to rexter
convert AV/ scart / VGA/ Ypbpr TO HDMI
Shenzhen lenekng Technology Co., ltd, which exploit and manufacture High Definition Video Converter.
http://www.lenkeng.com/EngLish/product.asp
contact person: Iris
E-mail: iris@lenkeng.com
TEL:86-0755-82500214
MSN: yejianfang014@hotmail.com
Reply to lenkeng2008
- 0 +
I agree that 30 ft. is quite a long run for either co-ax or glass but if there's no way to move the PC closer my only suggestion is:
http://www.partsexpress.com/pe/sho [...] er=180-949
I use shorter runs of this cable and am quite fond of it.
Reply to Thelly
There are 1155 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
