Tom's Hardware > Forum > Audio > Audio Technology > Hdmi Cable for connection from speakers to hdtv
Forum Audio : Audio Technology - Hdmi Cable for connection from speakers to hdtv
Hey, I recently bought a hdtv 1080p with a speaker system that comes with it from bestbuy.
I was told to get a hdmi cable to connect the speakers to the tv with it. I bought the hdmi cable for $80 from bestbuy then when I went online to newegg I found out that they sell the hdmi cables on newegg for around 20$-30$,I'm wondering is there any major difference in these cables should I just get the newegg hdmi cables? Please help!
Speaker I bought:
http://www.bestbuy.com/site/olspag [...] 3767791212
Hdmi Cable I bought from best buy:
http://www.bestbuy.com/site/olspag [...] 8558641784
Hdmi Cable from newegg 20$ !!!
http://www.newegg.com/Product/Prod [...] 6812196106
Sponsored Links
No. They're digital. They either work or they don't. You got sucker'd.
See if you can return 'em.
The same cable when properly searched for can be had for less than $10w/shipping
Honestly, and I don't mean to be rude, but shouldn't this kind of research be done BEFORE you drop your dough on something???
------------------------------ +35 Wingding approval points +10 Scouse approval +22 Mammary Manipulation
+5 Comedy +15 Belated Holy Points +5 Messianic Approval + 5 penile innovation
+13 Baked Ham creativity +65 Obscure Quote
Reply to KingLoftusXII
So I should return the cables and just buy it from newegg?
Reply to skydream
It depends on whether you want an extra $60 in your pocket.
Hmm guess I'l just return the cables to bestbuy and grab the newegg one. Thanks for comments :P
Reply to skydream
- 0 +
Speaker I bought:
the best connection is with HDMI Cable http://clink.com.au/hdmi/hdmi_cables.htm
Reply to perecoc
Never heard of speakers connecting with HDMI before. What brand TV ?
Reply to americanaudiophile
There are 522 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
