Tom's Hardware > Forum > Home Theatre > HDTV > TV/Monitor Advice
TV/Monitor Advice
Forum Home Theatre : HDTV - TV/Monitor Advice
First of all, great site. I've been around for quite a while now although never got round to signing up until now.
Now I'm pretty good with most electrical kit however when it comes to cables and wiring I just panic, so im here looking for some of you smart folk to help me out. My plan is to have a 22" TV/Monitor with a 360, PS3 and PC plugged into it. Now would I be right that the best method would be having the 360 and PS3 using HDMI and the PC using DVI :??:
If im wrong I'd really appreciate the help. Also I would like some advice on which TV/Monitor to get. Ive been looking at this one http://www.ebuyer.com/product/143850
And for people that dont like reading full sentences -
-Wanting 360, PS3 and PC in one TV
-Looking for HD TV that would be capable of the above
-Help :)
Finally, I'm in England if that helps anything, and if you'd like to imagine me in a manor drinking tea, then sure...have a ball.
Sponsored Links
I don't know too much about TV monitors, so I don't know if the one you're looking at is a good one. I keep hearing (here in these forums) about "good" monitors have 178 degree viewing angles. Maybe someone else can help clear that up (and maybe provide a link?).
As for how to connect devices, I'd say you have it right. Use the two HDMI ports to connect your PS3 and XBox and the DVI port to connect your PC.
-Wolf sends
------------------------------ System Specs:
Gigabyte EP43-UD3L Intel Core2Quad Q8400 8 Gig RAM
NVidia Geforce 8800GTS-640/Creative X-FI Extreme Music/Dual-Boot XP-64&Server2008
Reply to Wolfshadw
- 0 +
Thanks for the confirmation on that mate. Anyone got advice on the TV?
Reply to Solo-X
- 0 +
Hi guy,
Looking for a TV monitor with PC plug,accturely,I found a good website which is a china elecreonics wholesale.thire website is www.onvon.com
Maybe you could search what you want in this online shop.Good luck for you!
Rita
www.onvon.com
Reply to dudu125
There are 1051 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
