Tom's Hardware > Forum > Audio > Audio Technology > Wireless audio
Hello,
I have two PC and one set of PC speakers, I would like to share the audio from both PC on those speakers without using cables and Im looking for a solution.
So far, I've found the Apple Airport and a Linksys solution WMB54G
THe problem with the Airport is that in allows only input from iTunes (no system sound, games sounds ...) and I hate iTunes. :) The linksys solution seems to be fine but the BIG bad point is a configuration and usage which seems to be extremely tricky as I read in some reviews.
I would like to ask you if you know other solution for wireless audio.
Thanks in advance,
Tex
Message edited by RCPilot on 01-17-2008 at 10:59:40 AM
Sponsored Links
There is a mistake in title of the topic: ausio = audio ... could a moderator correct it ? thx
Reply to Tex-Twil
The title of this topic has been edited by RCPilot
Dazzle them with Brilliance, or Baffle them with Bull S-it!!!!!
Reply to RCPilot
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
