Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Possible to Change Write Speed on XP CD Burner?
Forum Windows XP : Windows XP General Discussion - Possible to Change Write Speed on XP CD Burner?
Archived from groups: microsoft.public.windowsxp.general (More info?)
I've been using XP's CD file burner feature, but is it painfully slow.
Is there a setting somewhere to speed it up?
Where is it anyway?
jim
Sponsored Links
At what speed is it writing at??
does that match the speed of the CD's you are using??
does this match the speed of the CD drive??
peterk
It's so much easier to suggest solutions when you don't know too much about
the problem
"jim evans" <jimsnews@houston.rr.com> wrote in message
news:gj1ed1tsnkpr89mfrj7mepci3lt5hsg6aj@4ax.com...
> Where is it anyway?
> jim
Reply to Anonymous
> Where is it anyway?
> jim
http://www.sonystyle.com/is-bin/IN [...] _CDBurners
Mike Pawlak
Reply to map
How to Set the Write Speed for a CD-R Drive in Windows XP
http://support.microsoft.com/?kbid=309522
Click the Recording tab, select the speed the CD recordable media will
be written ..
regards,
ssg MS-MVP
> Where is it anyway?
> jim
Reply to Anonymous
http://support.microsoft.com/defau [...] -us;309522
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Get Windows XP Service Pack 2 with Advanced Security Technologies:
http://www.microsoft.com/athome/se [...] hoose.mspx
| Where is it anyway?
| jim
Reply to Anonymous
Thanks much for the replies.
Mine is set to "Fastest" so I guess the XP burner is just slow.
jim
Reply to Anonymous
> jim
It isn't that XP's burning capability is slow. The speed of the drive is
what is really important. If you have an older cd-rw drive, just go buy
a newer one. They are very inexpensive.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
There are 1108 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
