Tom's Hardware > Forum > Home Theatre > HDTV > Transporting 61" Sony Rear Projection (model KP-61HS30)
Forum Home Theatre : HDTV - Transporting 61" Sony Rear Projection (model KP-61HS30)
Hello everyone
This Friday I have to transport this TV to my house. I am going to transport it upright with blankets as padding and some couch cushions for the sides/front/back to minimize vibration. My question is: with it weighing in at 211lbs there is no way that the two of us can lift it into the truck with it remaining flat the entire time. Will it cause any/much damage if it were tilted at an angle? I planned on laying out some boards and placing the TV on a flat dolly (ones we use to move large stacks of items at work) and then rolling it into the back of the truck. Will this work safely?
Thank you for your help.
Shane
Sponsored Links
Whatever you do, never tilt a TV sideways when transporting it somewhere, even if it has enough boards and support to protect it, because no warranties cover accidental damage done to TV’s. My recommendation to you is to use an immense amount of saran rap over the TV screen and around the whole structure of the TV. This way you will have something to protect your screen. What kind of truck are transporting it in? Is it a open flat bed? Closed one?
Reply to x Steel x
Well it wouldn't be sideways..more at an angle..maybe 45 degrees at the most, but probably 30 degrees or around there.
It is an open flat bed truck...we are transporting it roughly 10 miles..pretty close. The road we will be ussing is a highway...around 40MPH is the speed limit. Then on the road to my house which is roughly 6 blocks off of the highway..residential...relatively smooth roads the entire way.
Reply to Criimson
You would typically want to lay the TV flat down when transporting to a destination. But considering that it is only a ten mile distance then it shouldn’t be too big of a hassle for you. I would still recommend saran rapping it before leaving with it.
Reply to x Steel x
Could you lay it on its face or back? aslong as it was wrapped
Reply to maperath
There are 642 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
