Bad Asus X800xt Problem: Strange Crash! HELP! :(
Last response: in Video Games
Anonymous
August 2, 2005 10:30:05 AM
Archived from groups: microsoft.public.games (More info?)
hi to all i have a big problem with my asus x800xt
i've buyed it from some days and always i have this problem: when i start a
game i see a black screen and at the center the withe cursos of windowsxp and
then the computer be stopped and i must reset and restart!
This problem there is also when i pust the button for enter in the catalyst
control panel (the old panel)
but these problems happen sometime but always in a day!
how i must do? i'm disperate!!!
i've cataly official 5.7 and i've tried to dis. vpu recover, fast write,
overdrive but nothing!
i've tried to set agp 4x but always nothing!
i've a power supply of 400watt zalman
my hardware: asus p4c800deluxe, p4 3.2 ghz @ 800, ddr400 dual channel
corsair 512x2, xp pro sp2 with all updates
now i try the omega drivers! but how i can do for solve this very bad problem?
please Help!
EDIT: some problem with last omega drivers!
Anonymous
August 2, 2005 2:55:18 PM
Hi Carmelo,
"Carmelo" <Carmelo@discussions.microsoft.com> wrote in message news:D E4787FF-673C-4743-B442-AC5D10CA217D@microsoft.com...
| please Help!
Hardware issues can cause freezing, black screens and other
errors. Also, your drivers should always be kept up to date.
Try the following steps one at a time to try and resolve the issue.
I hope this helps. Please post back if you have any questions! :-)
1. Update DirectX and your Chipset, Sound, &Video Drivers:
For all Video / DirectX / Game and Hardware Issues, I have a
Checklist of Solutions at: http://NibblesNbitsVideo.tk
2. Dust your fans, vents and components using a 1/4" paintbrush
and a hose vacuum. Use compressed air for hard to reach places.
Set a housefan to blow cold air into your case to expose an over-
heating issue.. If it works add more fans or replace defective ones.
Use this Motherboard Monitor Utility: http://mbm.livewiredev.com
3. A faulty power supply can cause STOP errors, random reboots,
and black screen lockups. One way to test for that is to check the
wattage sticker on your power supply and then calculate your need
http://www.jscustompcs.com/power_supply/ (Min. 350 for gaming)
4. Test your RAM using: http://oca.microsoft.com/en/windiag.asp
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
