Tom's Hardware > Forum > Audio > High-End Audio > Best sound out from PC, SPDIF or regular IO Speaker Ports
Forum Audio : High-End Audio - Best sound out from PC, SPDIF or regular IO Speaker Ports
In the middle of a new build. Will use onboard sound for now. Have Klipsch 4.1's that at 6 plus years old may have problems with preamp. My new DVD/CD is a Samsung 203B SATA (I know, hope it works, too). For the past year I have lost my 2 surround sound speakers and occasionally the wolfer, too. New DVD player seems to have SATA and power cables only, which go to mobo. I was thinking of hooking the sound up to the mobo CD receptor. Then wondered about using SPDIF for higher quality, of should I stay with the I/O speaker ports (7.1). Using Gigabyte EP35 DS3P mobo with xeon e3110 cpu.
And if the Klipsch are burned out, will the Logitech Z-5500 do justice for now. Can't afford top speakers now, with this $1,500. build.
Any thoughts and help would be gratefully received. This is something new that I haven't researhed much yet. Links be good, too!
Sponsored Links
Logitech Z-5500 has digital and analog connection so connect both and choice the best suited for your needs.
Digital - If playing Movies and DVD-audio, some Audio CD works best on digital too.
Analog - If digital signal won't give give better controls on some materials you're trying to play.
Reply to rexter
There are 775 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
