Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > DiamondPoint SB70 problems
Forum Computer Peripherals : CRT Monitors - DiamondPoint SB70 problems
I have a mitsubishi Diamondpoint SB70 that my mother gave me because my HP monitor just quit turning on. The first time I plugged it in it turned on and all of the Icons were big and pixely. I went to adjust the screen resolution and the screen went blank and then there was a red and whit box that I cannot get rid of or do anything with. It says : Attention Signal Frequency is out of range FH>86.2 FV>59.9 Please change signal timing.
I cant do anything, it wont respond to anything I do. Ive turned off the computer unplugged the monitor etc, etc. What do I do?!!!!!!!!!!!!!!!!!!!!!!!!
Sponsored Links
Try booting on safe mode and then changing resolution down to 640x480. After that boot normally and increase the resolution/frequency only up to the point that is supported by your monitor. Also check the box that does not allow you to choose frequencies higher than those supported by the monitor.
Reply to realzeus
There are 1272 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
