I bought new PC with 5.1 Logitech X-540 speakers.Everything is ok,and computer recognise all speakers, but when I am listening music or playing games there is no sound from two rear spekaers, can anyone help me?
well, unless your soundcard supports multi channel upmixing then there is no reason why you should here music which is stereo from anything other than 2 speakers.
also, unless you have the correct speaker setup selected in your games menu's you won't here audio from the rear ones either.
baiscally you will only here sound from the rear speakers if there is supposed to be sound coming from them.
------------------------------I'm a git, deal with it.
I have the same speakers. All 5 speakers should be playing no matter what type of sound is played. Without matrix mode enabled, stereo music should have the left rear and left front play the same channel and right rear and right front play the same channel. Hitting the matrix mode button will balance the volume on all 5 speakers and changes the frequencies coming out of each one.
How is that possible? Matrix is a regular surround and not discreet surround so it can not have a balance output. It’s confusing to some people when you said balance the volume on all 5 speakers. The output of front and rear can handle the same power but not same sound level, ‘will not in the same volume if matrix is active. Only in quadraphonic mode that will have that ability. That is why in matrix mode sounds always quieter on the rear.
I just bought the Logitech x-530 5.1 speakers system.
I installed the latest drivers for SoundMAX built in soundcard in Asus P5B
I have configured windows Vista 32 bits, for a 5.1 system.
I ran the test and they ALL work when testing.
BUT when playing games, music, dvd's, CD's, EVERYTHING, I only get sound out of only Front L and R + Subwoofer and not from center + rear L and R
and strangesstranger, that's not true. I used to have the creative 5.1 running on windows XP, no matter what i played, sound came from evreywhere.
could anybody help me here??? this seems to be a pretty common problem but haven't found a solution....
Logitech X-540 have matrix built in and can be turn on or off, but the X-530 has not.
Although the codec that comes with
Vista is pretty good, Try to install Klite Codec Pack. http://www.codecguide.com/download_mega.htm makr sure you backup your system before installing it where you can revert if somethings goes bad.
they removed a sound thingy in vista, idr what it is i think DirectSound or sumthing, it screws it all up. Idk a fix for soundmax unless u have realte kread my other post i nthis section
