Tom's Hardware > Forum > Systems > Packard Bell > Battery replacement
Battery replacement
Forum Systems : Packard Bell - Battery replacement
I have a packard bell legend 20cd which I received a message today dead battery needs replacing. I have misplace my manual where is battery located? Is it avaiable? a quick reponse would be appreciated to
David
intruderdct@hotmail.com
Sponsored Links
Open your computer and you would see a coin like unit. Take it out and to the store. Replacement number is CR 2032 and easy to find. It's a dry cell lithium-Ion battery 3V.
Just remember how you take 'em out (+) side always facing you.
Reply to rexter
The battery is hard soldered to motherboard.
Reply to David-21
- 0 +
2 option.
1) Ignore the message, unless you can find away to disable the message report from the bios which I doubt there's any. P.B. went to solder the unit the board to cut cost.
2) Get someone to replace the battery with battery holder unless you can do it yourself.
There is really not much on the bios that require re-configuring if there's a power failure except time and date. It's not crucial if you can't replace the battery.
Reply to rexter
There are 572 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
