Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Best Sweet Spot Monitor?
Forum Computer Peripherals : Flat Panels/ LCDs - Best Sweet Spot Monitor?
I'm looking for a monitor thats between $200 & $300.
I want it to be pretty good in everything, games / watching movies etc.
Preferably, 17" to 22"
Thanks for any comments or suggestions. Thanks Storm~
Sponsored Links
A very recommended 22" monitor, a monitor i'm buying in the next couple of days is the Samsung 226BW.
http://www.newegg.com/Product/Prod [...] 6824001096
And believe me, i've done extensive research in the field, read endless reviews and benchmarks.
Everyone wants the perfect monitor for gaming, fast response time, high contrast, rich color, etc...
This is as close as it gets in that price range.
Reply to GJX
If you could post why this one beats everything else , its advantages over everything else and why it's the best bang for the buck basically, id really be appreciated.
If I could get some more opinions and suggestions from more people, also would be very appreciated. Thanks allot Storm~
Reply to Storm1234
Here are a couple of links that reviews 22" LCD monitors:
22 inch LCD monitors: The second coming!
See page 6 for a summary as to why many people recommend the Samsung 226BW. One word of warning, the monitor reviewed uses the "S-panel" made by Samsung. There are at least three different panels used to make this monitor and it is no longer possible to determine which panel your monitor uses unless you are willing to rip apart the monitor. The "A-panel" is considered to be good, but not as good as the "S-panel". The "C-panel" is considered the worst. There are rumors of a "P or T-panel".
Here's the second review article:
22 inch LCD monitors: the 3rd wave!
Personally, I hate 22" monitors because they use the inferior TN panel technology, so I will not make a recommendation.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Interesting article but unfortunately the current price (in Finland) is near and even above 350e (outrageously spendy 500$) for these screens. I'm interested in a 22" screen but can't buy any of the tested screens. My options a.re something like Acer x223w, x221wa, FJ L22-w5, or Samsung vw222s, Benq T221wa. If you are bored check out <a href="http://www.pixmania.com/fi/fi/11124/xx/xx/1899/9/criteresn.html?s=11124&m=xx&t=xx&categorieid=9&cat=1899&startrow=&sortBy=ASC&orderBy=Prix">pixmania's selection 22"</a> and make a suggestion. I am hoping to spend 200-250euros.
Reply to thewanderer
Sorry I mangled that one. The screens in the article were pretty spendy, but here is the link...
I am hoping to spend 200-250euros. It'd be nice to get a 22" screen for the extra space, rather then a 20".
So if anyone is in the same situation and knows which is the better option, or is bored check out these screens.
http://www.pixmania.com/fi/fi/1112 [...] derBy=Prix
@ jaguarskx
Is there any monitors you would recommend between 17" - 24" / $250-$350 bucks? Doesn't have to be 22"...
Thanks very much Storm~
Reply to Storm1234
@ jaguarskx
Got any comments or suggestions jaguarskx ??
Reply to Storm1234
Well, I generally prefer higher end monitors 'cause they provide better quality.
$350 for a 24" LCD to me is like scrapping the barrel, but you might want to consider the:
Westinghouse L2410NM Glossy Black 24" 8ms Widescreen LCD Monitor 500 cd/m2 1000:1 Built in Speakers - It's selling for $349 after a $50 mail-in rebate. It got lots of good user reviews and it has a glossy finish. It uses an 8-bit S-PVA panel which can actually produce 16.7 million colors. Generally, that means better color accuracy, viewing angles and black levels, but response time is 8ms.
Just about everyone will tell you that the 22" Samsung 226bw is the best gaming monitor, but there is a catch. At least 3 different panels are used to make this product. In order of quality that would be S, A, C. Everyone has high praises for the S panel, the A panel is consider good, and C panel = crap. They only to tell which one you have is to rip apart the monitor and look at the serial number of the LCD panel itself. The rumor is that they recently "introduced" the P panel version. Despite these issues, it is still a top seller. The Samsung 226bw is selling for $270 @ Newegg.com after a $40 mail-in rebate.
Based on the articles I previously link, "22 inch LCD monitors: the 3rd wave!", the best monitor is the Iiyama ProLite E2201W. Not sure if they sell it in the US.
The ViewSonic Graphic Series VG2230wm Black 22" seems to be a good alternative if you don't want to deal with the Samsung's panel lottery. It's selling for $290.
Reply to jaguarskx
Anybody ever heard of Mirai? I guess this might be a 6bit panel due to the 16.2 million colors versus normal 16.7million. Just curious because its half the price of most recommendations.
DVI/VGA
5ms
700:1
http://www.pixmania.com/fi/fi/5934 [...] ml-52.html
I guess they are sold out of that Mirai...
There are 1195 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
