Wireless LAN adapter Wireless Network Connection
gargintua
I have installed the drivers for my wireless card but my network is not showing up
DETAILS
- Tp-Link WN951N
- Windows 7
- Problem started after installing new hardware in computer (motherboard)
- In the past, same problem started after installing new hardware (hard drive)
- This same problem was fixed with a reformat. (SERIOUSLY DO NOT WANT TO REFORMAT)
- Tp- Link driver cd is not detecting installed card
- Control panel\Network and Internet\Network connections
shows the wireless card enabled and getting a signal
-Tried all the Netsh reset, winsock, reset.log, catalog commands on cmd
C:\Users\******>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : ********-W7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Inte
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Tunnel adapter 6TO4 Adapter:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter isatap.{55120DBC-6756-4579-A8A9-5304D55D184B}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Its just a red cross over the network icon in the panel. :(
EDIT:its actually a tplink wn951n not a wn751nd
gargintua
Thank god!
I booted into safe mode
Deleted every wireless driver from program files and device manager
And installed the driver through Device manager havedisk for networkcontroller
Thank you so much mate!
you saved me a reformat!
