New/Replacement Hard Drive
Forum Laptops & Notebooks : General Laptops & Notebooks - New/Replacement Hard Drive
So I have a Dell Inspiron 8100 laptop, that has ONLY a 10GB hard drive. So I've been looking around the web and saw a few that interest me, the only problem are will they fit and work in the laptop and will they meet the laptops specifications or on the contrary will the laptop meet the hard drives specifications.
PS. I found a hard drive I think will fit but please, correct me if I am wrong. If anyone else has a better hard drive than the one below please give links.
http://www.tigerdirect.com/applica [...] CatId=1277
Sponsored Links
Are you sure that the system can handle a SATA drive? 10GB is pretty old technology and I don't remember anything that small when SATA was available but I could be wrong.
Reply to skornel
I don't know if it can handle a SATA drive, i think it can, but I know for sure it can handle a 120GB IDE drive.
Reply to spinaltap775
Find out your motherboard model and make and check up on the net to see if it has SATA support. Otherwise buying the drive you mentioned would be a waste. Of course you could still use it as an external hard disk, but that would be a waste of SATA's superior speed.
Reply to pitstop87
Okay then can someone tell me the model make, or can someone just give me a yes or no answer to the question, can a Dell Inspiron 8100 suport a SATA hard drive.
No that laptop won't support sata hard drives. But could someone please give me a few links to some good CHEAP IDE hard drives, that are bigger than 40GB.
"Cheap" is a relative term. You need a budget posted.
Anyway, here are all 2.5" 5400RPM ATA hard disks on newegg.
http://www.newegg.com/Product/Prod [...] rchInDesc=
Message edited by frozenlead on 08-08-2009 at 07:23:17 PM
------------------------------ Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17", 24" | Win 7 x64
Reply to frozenlead
My laptop will not support a SATA hard drive and if your really stupid and don't know by now, ATA is SATA because before the letters ATA is the word Serial, Serial ATA=SATA. So I need a cheap PATA or EIDE if you want to call it that hard drive. Thanks.
Thanks for calling me stupid, but you're incorrect. If ATA is SATA, then why is there a SATA category and an ATA category in newegg, and why did my link show disks with 80 pins on them?
ATA is the shortened term for ATAPI, which is also known as PATA.
http://en.wikipedia.org/wiki/Advan [...] Attachment
Edit: after reading a bit of the article, which is pretty cool, I found that PATA is actually a term only created after SATA was - so ATAPI is really the correct term. Not like it matters any, but whatever.
Message edited by frozenlead on 08-10-2009 at 01:14:54 AM
Reply to frozenlead
Well, I'm mistaken then, and sorry for calling you stupid, I've had a long few nights and getting stressed. So yeah I'll look into it and thank you.
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > New/Replacement Hard Drive
There are 1184 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
