Tom's Hardware > Forum > Home Theatre > HDTV > Off air antenna and cable tv
Forum Home Theatre : HDTV - Off air antenna and cable tv
can you use off air antenna with comcast cable?
Sponsored Links
You can use over-the-air antenna no matter what. You would just have to be able to have an input on your TV or computer tuner card to accept the antenna. There are *many* ways to do this. Probably the easiest way to figure out a way that will work for you is for you to post what your TV/cable setup is and we'll go through it.
------------------------------ Upcoming Overdue Build: Dual-socket workstation, ~32 GB DDR3, OS on a fast SSD, high-end GPU, all wrapped up in a huge tower case. Coming H2 2011.
Yes, I am actually still running the Pentium III 1.0B Coppermine in the picture.
Reply to MU_Engineer
There are 702 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
