I had the soundblaster live which seemed fine with all games. I don't have it anymore. Would you recommend me just getting that again or going to another card? I don't wanna spend more than between $50 and $100 and only that if it really makes a difference. Playing Doom 3 and games like that.
Get an Audigy 2 or Audigy 2 ZS. You will see a major difference in movies and newer games especially if you have surround sound. DD, DTS, and EAX4 make a difference
I had an SB Live that served me well since 1997 when it was released. But I wanted more, so I got the Audigy 2 ZS and it was a nice choice. I don't get the periodic crackling as I did before and the sound quality is just better.
However, in terms of Doom 3 I'm not sure if you'll see a difference performance wise since it uses the CPU not the sound card to process the sound.
