Correct batteries for charger
Forum Other Consumer Electronics : Other Consumer Electronics - Correct batteries for charger
I have received a Sanyo NC-MQR01J/U battery charger for Ni-MH/Ni-Cd batteries. It won't be used for anything but a wireless Microsoft mouse. The back of the unit states: DC 1.2v 460mAx4 / 920mAx2. I am familiar with these terms. My question is this, can I use higher mha batteries and still be allright? Also, what would you recommend as a good, cheap Ni-MH battery to use in this charger. Thank-You for taking the time to read this post. I'm just trying to go a little green buy re-using batteries.
Sponsored Links
Yes you can use higher capacity but it'll take longer to charge. Unless the charger have protection circuitry that protects itself and the battery, it will shut down when max allowed current is reach, or it'll damage the charger.
Reply to rexter
Tom's Hardware > Forum > Other Consumer Electronics > Other Consumer Electronics > Correct batteries for charger
There are 684 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
