Tom's Hardware > Forum > Systems > Dell > Dell Dimension 4700C power button problems
Forum Systems : Dell - Dell Dimension 4700C power button problems
Hey, I've got a problem that I've completely narrowed down but I don't know where to go from here. I fixed a customer's computer (just simple things like anti-virus install, and plugged in the cd drive that somehow managed to come unplugged) and then booted it back up and it worked fine. I called the customer to come get it, and she brought it home and then it wouldn't boot up. She brought it back, and I checked various things. Everything is getting power and all the components appear to be working fine...Except the start button. At first I tried to boot the computer via wake on lan, but that didn't work. However, it boots when I short out the two pins with a paperclip perfectly. How in the world do I replace a *Dell* power button? My terminology regarding this will be pretty terrible, but most power buttons are "divided" and you have to connect them to the pins in a specific order. The Dell one just connects to them all so it's impossible to tell which ones are the ones that I need to use. I looked at Dell's manual for that particular computer and it divined nothing.
What should I do? Should I just get a replacement power button from Dell or something for that specific model? Do they even sell those anymore?
Thanks!
Sponsored Links
There are 1353 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
  • 01:00 steelmartin won the Freshman badge
