I have an IBM-DTLA-307030 30MB disk on a Win '98 SE 128 MB system - 4 yrs old . The disk has played up and a part ahs bad sectors which even the IBM DFT ver 3.40 program cannot fix . As I have this disk logically divided with System Commander into 2 separate op systems , so the "second" Win 98 had it's swap file just in this place ( the IBM DFT program told me that - but couldn't fix it ) . I renamed it and put the swap file on another logical disk away from the problem area . Is there any program , which will let me actually define that old swap file ( 100 MB size ) - as a bad sector ? If I even just try to see the file's properties under Win 98 , the system hangs .
