Hello.
I have seen several similar posts regarding this, but have not been able to get a solution to fix the issue for me. I have searched on the net for hours regarding this issue and so far nothing has worked for me.
The problem : Using my headset when I talk on Skype/Ventrillo/Mumble, when I transmit, everyone can hear my computers audio. This isn't the mic picking up bleed from the headphones, they can actually hear everything i hear very clearly, whether its in game sounds or music.
I have almost narrowed this down to either my Motherboard, or Windows 7.
Hardware info:
Motherboard : ASUS M4A79XTD EVO
OS - Windows 7 Ultimate 64
Soundcard - Creative Xi-Fi Extreme
Headset : Razor Carcharias
What I have tried:
Uninstalled all Creative software, removed card from computer and activated on board sound instead.
Activated both sound cards, plugged in the headphones into the X-Fi card, and the Mic into the on board.
Made sure I have the latest drivers installed for both Xi-Fi and on board (creative driver is pretty ancient)
Used a completely separate microphone not attached to the headset.
Made sure all recording devices are switched off except the Mic.
Tried every kind of input and output volume controls, adjusting these does not seem to make a difference.
Made sure Stereo Mix is disabled (this option was only available when using the on board audio, not seeing this option for the Xi-Fi card)
Listen to device disabled.
I've also tried 2 other headsets and issue still persists.
Is there something I can do within Windows 7 to disable this from happening?
Hardware info:
What I have tried:
