Tom's Hardware > Forum > Systems > Dell > Inspiron 530 PSU upgrade and Graphics card upgrade help
Forum Systems : Dell - Inspiron 530 PSU upgrade and Graphics card upgrade help
I have a basic Dell Inspiron 530 and I would like to upgrade and put in a graphics card with no less than 512 MB and 256 bit. Everything that I've read for PSU recommendation on graphics cards is 450 watts or larger. What is a good power supply and graphics card combination that I should look at that is compatible with the Dell Inspiron 530? I have a price range of about $350.
Sponsored Links
If you can stretch to $360, then get an HD 4890:
http://www.newegg.com/Product/Prod [...] air%20650W
And for the power supply:
I'm assuming your processor isn't a pile of poo.
Reply to crazyguy_60
Just had a look at the Insprion 520, the processor is an Intel Core 2 Duo E6320, this may bottleneck the GPU slightly. If you don't want to take a gamble, an HD 4870 is perfect.
- 0 +
Welcome Adman100, what are your full PC specifications or are they the stock ones,
Reply to AKM880
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
