Weird sound...
Forum Computer Peripherals : Other Peripherals - Weird sound...
Hi,
My girlfriend got a weird sound coming out from her speakers. It is a Creative 2.1 Inspire T3000 set, plug into the onboard sound from her MSI K8N-sli-fi motherboard. It happens whatever she's doing, sometime they start buzing bip bip bip bip bip bip bip bip bip bip, it sounds like Morse code. They only way to stop it, is increasing the sound, but then it's way too loud for everyone around in the house. I can tell you it's not the MB, I just change it 2 weeks ago, and the problem was going on the older MB too, so it is really coming from the speakers.
Does anybody ever experiment something like this? Are the speakers almost dead? or defectuous?
------------------------------ Q6600 G0, Asus P5Q-E, 4GB PC6400 OCZ Reaper HPC, EVGA 8800GT 512MB Superclocked, SoundBlaster X-Fi Xtreme,1x Vraptor, 2x WD 320 GB RAID 1, Enermax Liberty 620W, Thermalright Ultra-120 Black
Sponsored Links
Try to plug speaker to a different outlet and sound source like a walkman/portable CD player.
Next is unplug any connection you are not using for the computer at the moment one at a time and check the sound by using a headphone.
Reposition the wiring so that and power AC line is away from low voltage lines like network cable, phone cable, speakerwires etc.
Most common mistake is intruducing EMI/RFI signal to a device is pluging things when it is turned on like speakers to computer while both are turned on.
Check your wiring for short or grounding. some equiment need to be grounded some does nothave to.
Reply to rexter
Maybe i had this the same problem also like your girlfriend had... i think maybe it's the CPU is the problem... but i haven't yet solve this problem
Reply to Anonymous
Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > Weird sound...
There are 1264 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
