Tom's Hardware > Forum > Systems > HP > Help me on which system
Forum Systems : HP - Help me on which system
Hello,
I want a system that can do some gaming and blu-ray.
I am considering HP with Phenom II X4 940 8 gig DDR2
http://www.shopping.hp.com/webapp/ [...] catLevel=2
or
Gateway i7 920 3 gig DDR3
http://www.bestbuy.com/site/olspag [...] 8017465909
In the gateway, I would have to add a blu-ray.
Thanks
Sponsored Links
Aftermarket Blue-ray burners/drives are not cheap at all, if you want a good one...so....
In regards to the systems, I would push towards the HP...I personally like HP as a brand because of the quality of their products, plus AMD processors are much more reasonably priced for what they offer.
The processors you have highlighted in these two computers are:
AMD Phenom II X4 920-
Clock Speed: 3000MHz (3.0GHz)
L1 Cache: 4X128MB
L2 Cache: 4 x 512KB
L3 Cache: 6MB
Power Consumption: 125W
Intel Core i7-
Clock Speed: 2666MHz (2.66GHz)
L1 Cache: 32KB
L2 Cache: 4 x 256KB
L3 Cache: 8MB
Power Consumption: 130W
Although the i7 Machine will be using DDR3 RAM, it will only be using 3GB of it. 8GB of DDR2 should well outperform the DDR3.
Even with all of their differences, the systems are very similar, and it more or less up to you and your preferences. Good luck.
Reply to lauxenburg
There are 1219 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
