Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > HP/Compaq nx7400 screen issue...help please!
Forum Laptops & Notebooks : General Laptops & Notebooks - HP/Compaq nx7400 screen issue...help please!
I have a HP/Compaq nx7400 laptop which was given to me free as "broken." When you power it on, the screen backlight comes on however nothing is displayed. The screen slowly changes through a dark rainbow pattern.
I hooked the laptop up to my HDTV via a VGA cable and get perfect output onto the HDTV from the laptop. via it's VGA port.
Is this just a case of a bad LCD I could simply swap with a new one and have a fully functional laptop or is it something with the system board?
Sponsored Links
No, you tested the notebook successfully; the board is working correctly. The screen is the problem, and replacing it should solve your issue.
Reply to frozenlead
yes i agree with frozenland, especialy if your backlight inverter seems fine so yeah a rep screen will do it.
Reply to pcfixed
Hi :)
In first place sorry for my english.
The same happened to me. A friend brought me a Compaq nx7400 notebook with same symptoms as you describe.
But when i power on the notebook, screen turns on and i should be looking on that big HP logo, but all i get is that "rainbow patterned" and blurry unreadable image. There no icons on the desktop, just big blurry rainbow image.
I hooked it to my LCD monitor via VGA cable hoping the problem is in the notebooks screen, but it wasn't. Almost the same image on the external monitor. Something like 256 colors mode and a lot of red in the screen.
When you're patient enough and you press "accidently something" the screen then sometimes come to normal until you reboot that machine.
So the problem is in the onboard Intel graphic card. Warranty is gone, and the replacement won't be cheap on a 3 year notebook i guess. How much can the replacement cost ?
Thanks.
Reply to poldy112
The replacement will cost as much as a new motherboard, plus the labor of whoever you hire to replace it (free if you do it yourself).
Reply to frozenlead
yeah. in that case the graphic chip overheats which is typical for hps..especialy the DV series what I usualy do is make custom copper heatsinks for the nb and sb bridge
did you try updating the graphic drivers? did you try winbios flash?
Reply to pcfixed
There are 1062 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
