Remove network, or reset network settings, help
I jsut installed win7, tried to connect via lan and got the whole chose what type of network thing. chose home.
But now I have a home network that does nothing
meanwhile in the network and sharing next to connections it says local area connection and when I click status a lot of sent/receiving
my laptop connects to the internet fine via the router.
My desktop does not have wifi, this has happened before. frustrating.
How can I delete that home network, or reset all the settings?
2 answers Last reply
More about remove network reset network settings help
  1. I'm not 100% sure what you're asking. But I think you're saying you've set up a wireless network that you cannot connect to since you don't have a wireless card. And now you want to get rid of it. Correct?
    If that is the case:
    Open Control Panel -> Network and Internet -> Network and Sharing Center.
    On the left side you'll see "Manage Wireless Networks"
    You should be able to click whatever is there and say remove. (if that's what you wanted)
    I hope it helps
  2. I think that was it. although after I removed it it still did not work.
    I ended up just giving my lan an ip address, 192.168.1.xxx in the range that my router assigns. Gateway, 192.168.1.1, dns 192.168.1.1 and 192.168.1.0. Since my router is a client bridge it worked, DD-WRT.
    Saw this method posted elsewhere and it worked, not the most elegant solution but I am online now. I'd rather have it set so that an ip and stuff is auto assigned by my router, but this works fow now.
Connection Windows 7
