Tom's Hardware > Forum > Audio > High-End Audio > Need advice on a sound card. Is it worth my money?
Forum Audio : High-End Audio - Need advice on a sound card. Is it worth my money?
So I'm looking at maybe getting a sound card. I've read that they are definately worth it and your sound is greatly improved.
My Speakers (I have the 2.1 speaker set instead of 5.1. Same exact satellites and subwoofer)
http://www.newegg.com/Product/Prod [...] 6836121126
My current sound codec: Realtek AC97
I do not plan on buying better speakers. If I do, I'd get the set linked above. (ha, yes I'm cheap).
The sound card I'd like to buy when it drops to $50-$60:
http://www.newegg.com/Product/Prod [...] 6829102006
QUESTION ==============================
With my current speakers, will this sound card make a big difference in sound for my games? I play RPGs (Oblivion), lots of RTS's, and just about every other genre besides FPS.
Thanks :hello:
Sponsored Links
It will probably not make a noticeable difference.
Message edited by cjl on 10-02-2008 at 05:07:05 PM
Reply to cjl
- 0 +
1. Does anyone else agreed or disagree with cjl?
2. If I got some surround sound headphones would the sound card make a difference? I'd probably be want to spend $30-50 on them.
http://www.newegg.com/Product/Prod [...] rder=PRICE
Message edited by hoihoi8 on 10-02-2008 at 10:10:37 PM
Reply to hoihoi8
- 0 +
Try this first. Play a CD using Power DVD program ver.6 and up. On the preset equalizer select "SOFT", if you like the sound on that preset then a soundcard may be worth upgrading.
Best if you were to get Creative speakers instead and add it to your existing one, as the sound coming out of the Creative satellite is crispier than the Logitech, giving you more speakers and also increasing your Sub sonic level.
http://www.newegg.com/Product/Prod [...] 6836116024
Or
http://www.newegg.com/Product/Prod [...] 6836116025
Reply to rexter
I think you will notice a difference, but not with everything. My advice, spend 90 bucks on a better speaker system rather than your card.
I have the Razer Barracuda and noticed a difference. Some bigger than others. I have the 5.1 you labeled. The best part is it taking some load of your cpu, but mine is changing the bass settings and other misc tweekings.
------------------------------ HP 2207 22" Monitor, AMD 6400+, 8800gt SC 2x2gb G-Skill DDR2 800, GIGABYTE M55SLI SLI AM2Motherboard, 160gb Sata WD, 250gb Sata WD Philips 20x Dvd Burner, OCZ 600w PS, Razer Turantula and Logitech MX518.
Reply to Underbyte18
hoiho depends what are your wishes to do with soundcard,..do you want just for playing games,.. or for audio recording??? if so, than buy good speakers and good soundcard,.. for your budget you will not get good sound far from very good sound,.. the codecs ac97 you have probably integrated with your motherboard, this audio cores have big latency,cracks and pops, but for playing games they are very good,...
this sound will not have big differences iy you buy pro speakers from Alesis, Genelec, yamaha, Fostex,.. if you have bad soundcard the sound will be bad ,.. you must have both good quality ..cause of latency issues, sound quality and speaker frequencies response of your stereo speakers ,desktop or any other
Reply to harmony690
There are 1423 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 20:19 israil won the Sophmore badge
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
