Tom's Hardware > Forum > Audio > Pro Audio > I get low signal when I connect my preamp to 002 someone can help?
Forum Audio : Pro Audio - I get low signal when I connect my preamp to 002 someone can help?
Hi I have a problem when I connect my universal audio solo 610 to the analog inputs of the digidesign 002.
This is the way i do it:
1.- conect a mic with cable XLR to the preamp ( mic is a condenser and have the 48v phanton power of the preamp on)
2.- conect a cable XLR/ TRS from the preamp to the 002
3. I set volume and gain up and I can record but the signal is to low doesnt have volume
Then I just conect my premp to the inputs of the 002 that have preamp and sounds good but in that way I m mixing the sounds of the 2 preamps.
am I missing something else to get gain? Somebody have an idea of what is happening here?
Sponsored Links
Do you have a Pad activated? Have you made sure you are on the proper Mic / Line setting on the Digi? Try a different cable?
Reply to dark_matter
- 0 +
after you record your data go to audio suite and select normalize. itll bring it way up without burning it
Reply to saalhir
There are 1227 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
