Tom's Hardware > Forum > Home Theatre > HDTV > Sony HDTV projection unit has very small spots showing.
Forum Home Theatre : HDTV - Sony HDTV projection unit has very small spots showing.
I have a rear projection BRAVIA HDTV that has multiplying small spots showing on the screen. The keep growing and now cover about half the screen. I replaced the lamp, but to no avail! Do you have a solution?
Sponsored Links
If you know how your projector works it would have save you the cost of the bulb.
http://electronics.howstuffworks.c [...] on-tv1.htm
Projectors are like the one use at the movie theater; If light is busted; it's black. If no flim is presented thers white light and if the film is scracth you see it on the screen.
If you don't see this problem other than watching a TV then it's your tunner.
If you see this problem even playing other video signals, then it's the image processing.
You need to take the TV to a shop if you really love your projection unit. Cost of replacing that parts could be anywhere between $200 - $500 depending on the component.
New 42" LCD is around $1000.
Reply to rexter
There are 1075 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
  • 01:00 MasterSaji won the Uniformed badge
